跳转到主内容
2006 Honda Shadow Spirit 750 Battery Replacement
你所需要的
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: 步骤 1 中的图像 1,1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 步骤 2 中的图像 1,3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 步骤 2 中的图像 2,3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 步骤 2 中的图像 3,3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: 步骤 3 中的图像 1,2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: 步骤 3 中的图像 2,2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: 步骤 4 中的图像 1,1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: 步骤 5 中的图像 1,1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: 步骤 6 中的图像 1,1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: 步骤 7 中的图像 1,1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: 步骤 8 中的图像 1,1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: 步骤 9 中的图像 1,1
    • Remove the battery from the bike by pulling upwards.
结论
9等其他人完成本指南。
团队
USF Tampa, Team 1-7, Donnelly Fall 2014 USF Tampa, Team 1-7, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G7
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 85
总计 18,793
