跳转到主内容
2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement
你所需要的
  1. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 步骤 1 中的图像 1,2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 步骤 1 中的图像 2,2
    • Pull the release lever for the hood.
  2. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 2 中的图像 1,1
    • Slide the latch under the center of the hood to the left and then open the hood.
  3. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 3 中的图像 1,1
    • Disconnect the positive battery terminal by loosening the 10 mm nut and pulling the wire of the red battery terminal.
  4. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 4 中的图像 1,3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 4 中的图像 2,3 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 4 中的图像 3,3
    • Remove the connector attached to the TPS by sliding back the red clip and pulling.
  5. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 5 中的图像 1,1
    • Use a T20 Torx screwdriver to remove the two bolts holding in the sensor.
  6. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 6 中的图像 1,2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 6 中的图像 2,2
    • Remove the old TPS.
  7. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 7 中的图像 1,1
    • Install the new TPS and put the two T20 Torx bolts back in.
  8. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 8 中的图像 1,1
    • Connect the connector to the new TPS and make sure the red clip is pushed forward.
  9. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 9 中的图像 1,1
    • Reconnect the positive battery terminal, by tightening the 10 mm nut and putting the red cover back over it.
  10. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 10 中的图像 1,1
    • Close the hood and make sure it is closed securely.
  11. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 步骤 11 中的图像 1,1
    • Start the car and make sure that it is running normally.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 61
总计 3,346
