简介
This guide will show you how to remove the door handle, the main and two upper panels, the bottom latch, and the cable itself in a simple and safe way. This fix should take about 10 steps.
你所需要的
Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
Insert the screwdriver into the small opening found at the top of the plastic cover.
Carefully tilt the screwdriver upward to remove the plastic cover.
2等其他人完成本指南。
