跳转到主内容
加入维修社区 - 创建账户
2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement
你所需要的
    1. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement, Rear Cigarette Lighter - 2006 Chevy Trailblazer LT Fuse: 步骤 1 中的图像 1,2 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement, Rear Cigarette Lighter - 2006 Chevy Trailblazer LT Fuse: 步骤 1 中的图像 2,2
      • Pull the tab to lift the rear drivers side seat bottom and reveal the area underneath.
      询问修复机器人
      添加评论
    2. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 2 中的图像 1,1
      • Lift the bottom edge of the cover of the fuse box on the side closest to the driver’s seat.
      询问修复机器人
      添加评论
    3. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 3 中的图像 1,1
      • Press both side buttons on the black box at the same time to lift off the top cover.
      询问修复机器人
      添加评论
    4. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 4 中的图像 1,2 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 4 中的图像 2,2
      • Use a fuse remover tool or pliers to remove the 20 Amp cigarette lighter fuse.
      • Pull straight up to remove it.
      询问修复机器人
      添加评论
    5. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 5 中的图像 1,2 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 5 中的图像 2,2
      • Take the new 20 amp fuse and insert it into the same slot where the broken fuse was removed.
      • Once the fuse is aligned with the socket, push it down into the slot until it is fully inserted.
      • Be careful not to bend the pins while inserting the fuse.
      询问修复机器人
      添加评论
    6. 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 6 中的图像 1,3 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 6 中的图像 2,3 2006 Chevy Trailblazer LT Rear Cigarette Lighter Fuse Replacement: 步骤 6 中的图像 3,3
      • Replace the black box cover.
      • Press the cover down until it clicks into place.
      • Be gentle to avoid breaking the side buttons.
      • Replace the gray cover of the fuse box.
      • Ensure the cover is aligned with the box and then press down until it clicks securely into place.
      • Lift the seat bottom back into its original position.
      询问修复机器人
      添加评论
结论
You have now successfully replaced the fuse and reassembled all components.
取消:我没有完成这个指南。
Mark Boushell
于10/19/25注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 85
总计 472
