跳转到主内容
2006-2008 Isuzu i-Series Wiper Motor Replacement
你所需要的
  1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nut Caps: 步骤 1 中的图像 1,1
    • Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
  2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 步骤 2 中的图像 1,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 步骤 2 中的图像 2,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: 步骤 2 中的图像 3,3
    • Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
  3. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: 步骤 3 中的图像 1,2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: 步骤 3 中的图像 2,2
    • Once the necessary nuts are removed, the wiper blade itself can be removed.
    • This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
  4. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: 步骤 4 中的图像 1,2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: 步骤 4 中的图像 2,2
    • Open the hood of the truck for easier access to the wiper cowl.
    • Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
  5. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 步骤 5 中的图像 1,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 步骤 5 中的图像 2,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: 步骤 5 中的图像 3,3
    • Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
    • Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
    • The wiper cowl is flexible and can therefore be removed a little bit at a time. Take your time.
  6. 2006-2008 Isuzu i-Series Wiper Motor Replacement: 步骤 6 中的图像 1,3 2006-2008 Isuzu i-Series Wiper Motor Replacement: 步骤 6 中的图像 2,3 2006-2008 Isuzu i-Series Wiper Motor Replacement: 步骤 6 中的图像 3,3
    • Locate the two screws on each side of the wiper assembly.
    • Use a 10mm socket or wrench and remove each screw.
  7. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 步骤 7 中的图像 1,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 步骤 7 中的图像 2,3 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: 步骤 7 中的图像 3,3
    • Rotate assembly towards the windshield while starting to remove it from the truck.
    • Unplug the wiring harness located towards the driver's side of the truck.
    • The wire can then be fed through to remove the assembly the rest of the way.
  8. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: 步骤 8 中的图像 1,2 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: 步骤 8 中的图像 2,2
    • Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
    • Remove the three motor bolts with a 10mm wrench or socket (orange circles).
    • The wiper motor is now able to be replaced.
结论
3等其他人完成本指南。
Alex
于10/08/14注册
211 声望
撰写一个指南
团队
USF Tampa, Team 1-9, Donnelly Fall 2014 USF Tampa, Team 1-9, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G9
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 35
总计 3,956
