跳转到主内容
2006-2011 Honda Civic Key FOB Battery Replacement
你所需要的
  1. 2006-2011 Honda Civic Key FOB Battery Replacement, Key FOB Battery: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
  2. 2006-2011 Honda Civic Key FOB Battery Replacement: 步骤 2 中的图像 1,1
    • Gently lift the outer shell and remove it from the rest of the device.
    • Be careful not to break the clip located at the hole for the key ring that holds the shell in place.
  3. 2006-2011 Honda Civic Key FOB Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
  4. 2006-2011 Honda Civic Key FOB Battery Replacement: 步骤 4 中的图像 1,1
    • Unclasp the inner shell using the clips on the top and bottom.
    • Careful as to not break the clips as it keeps moisture, dust, and dirt from entering the delicate electronics.
  5. 2006-2011 Honda Civic Key FOB Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery inside of the inner shell of the key FOB.
    • If the battery is corroded, make sure to wear gloves due to battery acid.
    • Do not puncture the battery when removing the old one/placing a new one.
  6. 2006-2011 Honda Civic Key FOB Battery Replacement: 步骤 6 中的图像 1,1
    • Replace the old battery with a new one.
结论
To reassemble your key FOB, follow these instructions in reverse order.
3等其他人完成本指南。
Erika Caushi
于03/22/21注册
223 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G6, Riel Spring 2021 UMass Dartmouth, Team S1-G6, Riel Spring 2021 的会员
UMASSD-RIEL-S21S1G6
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 63
过去 7 天: 490
过去 30 天: 2,323
总计 65,400
