跳转到主内容
2006-2011 Honda Civic Dome Light Replacement
你所需要的
  1. 2006-2011 Honda Civic Dome Light Replacement, Dome Light: 步骤 1 中的图像 1,2 2006-2011 Honda Civic Dome Light Replacement, Dome Light: 步骤 1 中的图像 2,2
    • Before replacing the dome light and to avoid a short circuit, disconnect the car battery first.
    • Open the hood of your car by pressing the front latch and lift the hood.
    • Carefully attach the hood strut, (located towards the left of your car's engine), into the slot to hold the weight of the hood.
    • Disconnect the positive terminal of the battery in order to avoid short circuits.
  2. 2006-2011 Honda Civic Dome Light Replacement: 步骤 2 中的图像 1,2 2006-2011 Honda Civic Dome Light Replacement: 步骤 2 中的图像 2,2
    • Use a spudger and insert it into the space between the dome light cover and edge.
    • Gently pry the cover off but be careful that you don't break any of the clips attaching the cover to the assembly.
  3. 2006-2011 Honda Civic Dome Light Replacement: 步骤 3 中的图像 1,1
    • Evaluate if the bulb is just loose or if it has burned out and needs to be replaced.
    • In this case, you can see that the bulb has turned black from the inside, indicating it has shorted out. This bulb needs to be replaced.
  4. 2006-2011 Honda Civic Dome Light Replacement: 步骤 4 中的图像 1,2 2006-2011 Honda Civic Dome Light Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to detach the bulb from one end of the socket.
    • Pull the bulb out of the socket with the end that is loose.
  5. 2006-2011 Honda Civic Dome Light Replacement: 步骤 5 中的图像 1,1
    • Align the new bulb with the socket and push it back into place.
    • Ensure the bulb is connected to each end of the socket or it will not function.
  6. 2006-2011 Honda Civic Dome Light Replacement: 步骤 6 中的图像 1,3 2006-2011 Honda Civic Dome Light Replacement: 步骤 6 中的图像 2,3 2006-2011 Honda Civic Dome Light Replacement: 步骤 6 中的图像 3,3
    • Before attaching the cover of the dome light, reconnect the car battery carefully and test the light to make sure it works.
    • Align the tabs on the dome light cover with the holes in the assembly and push the cover back into place.
  7. 2006-2011 Honda Civic Dome Light Replacement: 步骤 7 中的图像 1,1
    • You should now have a functioning dome light.
结论
Hashim
于10/17/22注册
145 声望
撰写一个指南
团队
York University, Team B-1, Allen Fall 2022 York University, Team B-1, Allen Fall 2022 的会员
YORK-ALLEN-F22SBG1
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 67
总计 1,598
