跳转到主内容
2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement
你所需要的
  1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement, Liftgate Latch/Back Lock Sub-Assembly: 步骤 1 中的图像 1,2 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement, Liftgate Latch/Back Lock Sub-Assembly: 步骤 1 中的图像 2,2
    • Open the trunk door if you are able to do so.
    • Opening the trunk door will allow you to more easily remove the trim and access other components.
    • If you cannot open the trunk, ignore this step. The guide will show you later on how to open a stuck truck door.
  2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 2 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 2 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 2 中的图像 3,3
    • Pull upwards on the plastic covering the trunk strap to remove it.
  3. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 3 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 3 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips screwdriver, remove the screw holding the trunk strap.
  4. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 4 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 4 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 4 中的图像 3,3
    • Use a plastic trim kit to start removing the trim on the trunk door.
    • You may have to use your hands and pull if you have difficulties removing the trim.
  5. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 5 中的图像 1,2 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 5 中的图像 2,2
    • Use a 10 mm socket wrench or ratchet and remove the 8 screws located on the edge of the metal trunk cover.
    • Don't worry about the metal trunk cover falling off; there are plastic discs holding it in place.
  6. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 6 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 6 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to partially pry open the plastic discs holding the metal trunk cover and push the trunk cover off the discs.
  7. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 7 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 7 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 7 中的图像 3,3
    • Use a flashlight to follow the black cable that leads to a plastic covering which hides door latch cable.
    • Use your fingers to pull down on the plastic covering and remove it.
  8. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 8 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 8 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 8 中的图像 3,3
    • Use your hand to pull the cable downwards to release the bottom half of the cable.
    • Push the cable towards the metal ball and push downwards to release the cable fully.
  9. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 9 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 9 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to pry open the plastic holder and take the cable halfway out.
    • If you were unable to open the trunk door on the first step, you can now open it by pulling the metal ball on the black cable. This will open the trunk.
  10. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 10 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 10 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to pry off the plastic covering the trunk latch.
    • Use a 10mm socket wrench or ratchet to remove the three screws.
    • Push upwards and in on the trunk latch.
  11. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 11 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 11 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 11 中的图像 3,3
    • Using your fingers or a spudger, squeeze both sides and push in.
  12. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 12 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 12 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 12 中的图像 3,3
    • Use a flashlight and your hands to squeeze to remove white plastic plug connected to the trunk latch.
  13. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 13 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 13 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 13 中的图像 3,3
    • Using your hands, slide the trunk latch to the right side of the trunk and remove.
  14. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 14 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 14 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 14 中的图像 3,3
    • Use a spudger or your hands to squeeze and remove the black plug.
  15. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 15 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 15 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 15 中的图像 3,3
    • Use a Phillips screwdriver to remove the two screws holding the plastic trunk latch cover.
  16. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 16 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 16 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 16 中的图像 3,3
    • Use your hands to pull downwards on the black cable to expose more of the trunk latch from the plastic covering.
    • Remove the plastic covering by pulling it clockwise from the trunk latch.
  17. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 17 中的图像 1,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 17 中的图像 2,3 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 17 中的图像 3,3
    • Use a Phillips screwdriver to remove the two screws holding the actuator motor to the trunk latch.
  18. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: 步骤 18 中的图像 1,1
    • You can now reuse or replace your old actuator motor and attach it to a new liftgate latch.
结论
Evan Jimenez
于04/12/21注册
277 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 44
总计 2,526
