跳转到主内容
2005 Mustang GT Serpentine Belt Tensioner Replacement
你所需要的
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: 步骤 1 中的图像 1,1
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 2 中的图像 1,3 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 2 中的图像 2,3 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 2 中的图像 3,3
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 3 中的图像 1,2 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 3 中的图像 2,2
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 4 中的图像 1,1
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 5 中的图像 1,1
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 6 中的图像 1,3 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 6 中的图像 2,3 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 6 中的图像 3,3
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 7 中的图像 1,1
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 8 中的图像 1,1
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 9 中的图像 1,1
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 步骤 10 中的图像 1,1
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
结论
另外一个人完成了本指南。
Patrick Hall
于03/22/21注册
202 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 71
总计 2,336
