跳转到主内容
2005 Honda CR-V Car Visor Replacement
你所需要的
  1. 2005 Honda CR-V Car Visor Replacement, Car Visor: 步骤 1 中的图像 1,2 2005 Honda CR-V Car Visor Replacement, Car Visor: 步骤 1 中的图像 2,2
    • Ensure that the car is parked and utilize the parking brake.
    • Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
  2. 2005 Honda CR-V Car Visor Replacement: 步骤 2 中的图像 1,2 2005 Honda CR-V Car Visor Replacement: 步骤 2 中的图像 2,2
    • Remove the outer shell with a spudger.
    • When the outer shell is loose enough, remove it with your hand.
  3. 2005 Honda CR-V Car Visor Replacement: 步骤 3 中的图像 1,3 2005 Honda CR-V Car Visor Replacement: 步骤 3 中的图像 2,3 2005 Honda CR-V Car Visor Replacement: 步骤 3 中的图像 3,3
    • Remove the two 4.5 mm screws from the visor with a Torx screwdriver.
    • After removing the inner layer, the sun visor is now released.
  4. 2005 Honda CR-V Car Visor Replacement: 步骤 4 中的图像 1,2 2005 Honda CR-V Car Visor Replacement: 步骤 4 中的图像 2,2
    • Put the 4.5 mm screw removed in the previous step in the new sun visor.
    • Tighten the screw using a Torx screwdriver.
    • Also, note that the shape of the shell is aligned with the form of the hole in the roof.
  5. 2005 Honda CR-V Car Visor Replacement: 步骤 5 中的图像 1,2 2005 Honda CR-V Car Visor Replacement: 步骤 5 中的图像 2,2
    • Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
    • Ensure that the screws are tight.
  6. 2005 Honda CR-V Car Visor Replacement: 步骤 6 中的图像 1,3 2005 Honda CR-V Car Visor Replacement: 步骤 6 中的图像 2,3 2005 Honda CR-V Car Visor Replacement: 步骤 6 中的图像 3,3
    • Put the outer shell back on top of the inner shell.
    • Finally, ensure that the sun visor can be moved to the driver-side window and twisted upwards and downwards.
结论
To replace the new sun visor with the old sun visor, follow these steps in the same order.
An Chen
于04/05/23注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-24, Briggs Spring 2023 CSU Los Angeles, Team 2-24, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S2G24
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 47
总计 491
