跳转到主内容
2005 Honda Accord Engine Oil Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. 2005 Honda Accord Engine Oil Replacement, Using a Jack: 步骤 1 中的图像 1,2 2005 Honda Accord Engine Oil Replacement, Using a Jack: 步骤 1 中的图像 2,2
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. 2005 Honda Accord Engine Oil Replacement: 步骤 2 中的图像 1,2 2005 Honda Accord Engine Oil Replacement: 步骤 2 中的图像 2,2
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
  3. 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: 步骤 3 中的图像 1,2 2005 Honda Accord Engine Oil Replacement, 2005 Honda Accord Opening Hood Guide: 步骤 3 中的图像 2,2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  4. 2005 Honda Accord Engine Oil Replacement: 步骤 4 中的图像 1,3 2005 Honda Accord Engine Oil Replacement: 步骤 4 中的图像 2,3 2005 Honda Accord Engine Oil Replacement: 步骤 4 中的图像 3,3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  5. 2005 Honda Accord Engine Oil Replacement, Engine Oil: 步骤 5 中的图像 1,2 2005 Honda Accord Engine Oil Replacement, Engine Oil: 步骤 5 中的图像 2,2
    • Pull out the dipstick
    • Unscrew the cap from the oil tank
    • Set both aside. lay a towel over the engine block and set dipstick and the cap on that to avoid traces of oil.
  6. 2005 Honda Accord Engine Oil Replacement: 步骤 6 中的图像 1,3 2005 Honda Accord Engine Oil Replacement: 步骤 6 中的图像 2,3 2005 Honda Accord Engine Oil Replacement: 步骤 6 中的图像 3,3
    • Place oil pan between the front tires
    • Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank.
    • Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
    • Once the bolt is removed, oil will pour out of the hole very quickly. Position the oil pan under the hole before completely removing the screw.
    • Allow oil to drain until the flow is reduced to a slow drip.
  7. 2005 Honda Accord Engine Oil Replacement: 步骤 7 中的图像 1,2 2005 Honda Accord Engine Oil Replacement: 步骤 7 中的图像 2,2
    • Replace the crush washer on the drain bolt with a new one.
    • Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
  8. 2005 Honda Accord Engine Oil Replacement: 步骤 8 中的图像 1,1
    • Using a funnel, pour the new oil into the oil tank.
    • Honda recommends using 4 quarts of their synthetic blend 5w-20 Motor oil.
  9. 2005 Honda Accord Engine Oil Replacement: 步骤 9 中的图像 1,3 2005 Honda Accord Engine Oil Replacement: 步骤 9 中的图像 2,3 2005 Honda Accord Engine Oil Replacement: 步骤 9 中的图像 3,3
    • Put the dipstick back in.
    • Put the oil tank cap back on.
    • close the hood.
终点
5等其他人完成本指南。
Frank
于04/14/14注册
291 声望
创作了2篇指南
团队
Cal Poly, Team 12-35, Maness Spring 2014 Cal Poly, Team 12-35, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G35
4 名成员
创作了5篇指南
2条评论
Thanks. I was never able to find the oil filter before. Note that the Honda owner's manual lists oil capacity at 4.5 quarts, whereas you say 4 quarts; I don't know if this makes a difference.
JMY - 回复
Well-done.
The only issue I have is that I don't have the tools.
The explanations are ok
Olayinka Erinfolami - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 37
过去 30 天: 136
总计 49,647
