跳转到主内容
修复你的物品
维修的权力
商店
简介
An engine air filter is needed to filter the air flowing into the engine.
  1. Identify the open hood latch. It is located to the left of your brake pedal. Pull latch toward you. You should hear a click from the front of the car.
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. Walk to the front of the car. Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood. Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
  3. Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
    • Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
  4. Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
    • Unscrew the four bolts in the corners of the Air Filter Housing. This loosens the top of the housing from the bottom of the housing.
    • The bolts cannot be completely removed.
  5. Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing. It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
    • Next, separate the air filter housing from the bottom of the housing. To do this, with both hands, grab the Air Filter Housing from the exterior and push towards the engine block while pulling up.
    • It is easiest to remove the top of the housing by grabbing below the air filter, and removing the filter with the top of the housing.
  6. Remove the old air filter by gently pulling it from the top of the Air Filter housing. Replace the old air filter with a new one. The blue side should be facing down.
    • Remove the old air filter by gently pulling it from the top of the Air Filter housing.
    • Replace the old air filter with a new one. The blue side should be facing down.
结论
4等其他人完成本指南。
Matt Ondriezek
于2014年04月14日注册
483 信誉积分
创作了3篇指南
团队
Cal Poly, Team 12-35, Maness Spring 2014 Cal Poly, Team 12-35, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G35
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 19
过去的30天: 72
总计 4,076
