简介
If winter's setting in and your 2005 Chrysler Town & Country isn't warming the cabin well, isn't warming the cabin at all, or is leaking coolant, you likely have an issue with your heat flow/variable restrictor valve. This part is plastic and susceptible to damage, especially in older, high-mileage vehicles. This guide clearly will show you how to easily and quickly replace this part.
The valve is under the hood, right next to the firewall, and is responsible for managing the heat flow of coolant to the heating system. This can be a difficult area to maneuver in, so be careful with your hands when replacing the part.
It is very important to make sure your engine is completely cool before replacing your valve as you will be working right next to all of the hottest parts of your vehicle. Additionally, if your vehicle is not cool, some coolant might be lingering inside the heating system, which could result in coolant spilling on you, the ground, and your vehicle.
With that said, this is a relatively simple repair; all you need is the replacement valve, some pliers, and a pair of gloves.
你所需要的
Unlatch your hood by pulling the lever underneath the steering wheel.
Release the latch under the front of the hood.
Open the hood and insert the prop rod into the prop rod groove.
If there are leaks on the valve, repeat steps 1-9. Make sure the valve is in the correct orientation and the clamps are snug and properly secured. If a problem still occurs, there may be a hose leak in need of diagnosis and repair.
2等其他人完成本指南。
