简介
接下来的操作适合与所有配备了 Duratec引擎的福特福克斯,包括2.3L引擎的2004-2007款。 如机油加注盖所示,使用5W-20机油加注或更换机油。 这里有许多厂家生产多个适配于福克斯的油滤,因此您可能需要咨询当地汽车零配件柜台。
惯例是3000英里更换一次机油,但是现代机油和油滤能够坚持更长时间。 经常检查机油液位,使用常规机油可以轻松做到5000英里更换,使用合成机油就可以到达7500英里更换。
你所需要的
找到车下的油底壳上的排油塞。 这是一个13mm六角螺栓,面对着车后方。
在油底壳下放置接油盘来接住流出来的机油。 记住将接油盘对准车后方,,因为油会从油底壳里流出来。
使用13mm扳手来将排油塞松动,直到机油从油底壳流到接油盘中。
My 2006 ford focus sedan uses a size 14mm socket, not a size 13mm. I just got finished changing my oil yesterday and I had to use a size 14mm socket to fit my plug bolt. Make sure what Size socket your Ford focus actually uses so that you gace the correct size socket before you start your oil change. It's better to check the correct size before you get started so you don't have to back track searching for the correct size. I don't know if my oil pan bolt has been modified in some way or not. I just know I had to use a 14mm socket
逆时针旋转油滤(仰视)移走它。
将油滤放在排油盘中,垫圈面朝下,以使机油从其中排出。
让发动机的其余机油排出并收集在排油盘中。
Once the oil filter is removed carefully inspect the old filter and the filter seating surface on the engine for the gasket from the old filter. Sometimes this will remain in place and is a guaranteed major leak if not removed prior to installing the new filter.
My ex didn't check the old oil filter on my car and the o ring was left there, put on the new oil filter and blew my engine the next day. Always check!
让旧油滤残留的机油滴干,这通常会需要12-24小时。
带上你的旧机油和旧的油滤前往回收的地方吧。大多数的汽车零件商店和修理厂会无偿回收。 除此之外一些城市或者国家会提供上门回收旧机油和油滤。 详情参见美国石油协会的网站 http://www.recycleoil.org/
Wow! I feel like I'd rather change my oil than pay someone $20-30 to do
BizyMom229 - 回复
I paid $19 for 5 quart's of motor craft OEM 5-20w oil blend . At Walmart. No need to waste money on full synthetic. Your came from the factory with Motor craft 5-20w blend for a reason. Also bought a filter for under $4. In my area It cost over $60 at those oil change places for a oil blend with no say in what brand oil. U will have great satisfaction in doing the job yourself. Wear vinyl or nitrate gloves. Used oil is expecially toxic. P.S. always put news paper or painters disposable tarp cut to size. Under your drain pan. Expecially your first time u are bound to spill some of the old oil. Have fu
fordnut? -
I tighten oil filters by hand, and go as tight as I can. Some will say it’s not tight enough but if you have strong arms and hands it’s plenty tight, but not too tight as my gloves inevitability have a tiny residue on from removing the old filter. Never had a problem in 20 years. If you use a wrench, as said seat the filter gasket hand-snug then no more than 3/4 turn.
37等其他人完成本指南。
由衷感谢以下译者:
88%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
14条评论
Excelente aporte David. Muy útil la información para realizarlo de una manera eficiante.
Saludos
My 07 ford focus ses has just surpassed the 300, 000 klm mark. Only idem I've had to replace is the alternator in the past year.
Car is still running flawlessly. Iam shooting
For 500,000 klms. Think I'll make it?
How’s the car lasting?
How's she running?
I just passed 217000
As rcics -
Great instructional presentation. Thanks a lot.
Capt. Michael B. Cuanzon
1. Forgot to mention to park vehicle on level ground, turn off engine, wait at least 5 minutes & then check oil level.
2. The car engine roughly takes only 4 ½ quarts (4.3 L) of motor oil, With oil filter change. [otherwise you overfilled it.]
Could you please inform me is it possible to use in Ford Focus 2005 auto SL SX sedan the following oils:
5 l Valvoline SAE20W-50 API SG/CD
5l Valvoline Engine Armour Synthetic Blend for 15W-40 Motor oil
WOW! OUTSTANDING tutorial.
Sherri P2u - 回复
This is well done, but why pour the extra quart in a non running engine? It wont touch anything except the bottom of the oil pan. It wont flush the oil gallerys, or anywhere the oil pump is designed to take the oil. I csn see using a flushing compound with the old oil and letting the engine run for a few minutes to flush it, but what does pouring oil in a non running engine do? If i am missing something please reply and let me know. I am admittedly not a mechanic, just wondering how this might work.
Hahaha he forgot to tell you people how to reset the oil indicater light cause if you keep driving it after an oil change or two it will come on. He forgot to mention that you have to put the ignition to the on position and to hold down the gas and brake pedal at the same time for roughly 20 seconds. Hope I could help.
How do you change a diesel motors oil filter 1.8 ford banana utility 2006.
junejimmy3 - 回复
How do you fit a new oil filter to a ford bantam1.8 diesel utility van 2006
junejimmy3 - 回复
How do you fit a new oil filter to a 2006 ford banana 1.8 diesel utility van
junejimmy3 - 回复
