跳转到主内容
2005-2010 Scion tC Liftgate Support Strut Replacement
你所需要的
  1. 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 步骤 1 中的图像 1,3 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 步骤 1 中的图像 2,3 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 步骤 1 中的图像 3,3
    • Open the trunk hatch of the vehicle and have another person hold it in the fully open position.
    • Propping open the hatch with objects to replace the liftgate support struts can lead to serious injury and vehicle damage.
  2. 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 2 中的图像 1,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 2 中的图像 2,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 2 中的图像 3,3
    • Insert the screwdriver underneath the clip located on the end of the strut connected to the hatch lid.
    • Pry the clip away from the strut.
    • Pull the strut to disconnect the socket from the ball joint on the hatch lid.
  3. 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 3 中的图像 1,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 3 中的图像 2,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 3 中的图像 3,3
    • Insert the screwdriver underneath the clip located on the end of the strut connected to the vehicle body.
    • Pull the strut to disconnect the socket from the ball joint.
  4. 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 4 中的图像 1,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 4 中的图像 2,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 4 中的图像 3,3
    • Begin the installation of the replacement strut with the ball joint located on the vehicle.
    • Place the socket around the ball joint.
    • Push the socket onto the ball joint until the metal clip clicks into place.
  5. 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 5 中的图像 1,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 5 中的图像 2,3 2005-2010 Scion tC Liftgate Support Strut Replacement: 步骤 5 中的图像 3,3
    • Align the replacement strut with the hatch lid.
结论
To replace blown liftgate support struts for a 2005-2010 Scion tC, follow these instructions.
Spenser Brown
于10/03/20注册
129 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 19
总计 1,433
