跳转到主内容
2005-2010 Honda Odyssey Cabin Air Filter Replacement
你所需要的
  1. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate the Glovebox: 步骤 1 中的图像 1,1
    • Locate the glove box, which is positioned in front of the passenger-side seat.
  2. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Open the Glovebox: 步骤 2 中的图像 1,2 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Open the Glovebox: 步骤 2 中的图像 2,2
    • Pull on the handle to open the glovebox.
  3. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: 步骤 3 中的图像 1,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: 步骤 3 中的图像 2,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Dampener Hinge: 步骤 3 中的图像 3,3
    • Remove the cover of the dampener on the upper left-hand side (facing the glovebox) by pulling the semi-circular piece towards your body.
    • Pull the actual hinge outward and off of the cylindrical piece to which it was hooked.
  4. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: 步骤 4 中的图像 1,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: 步骤 4 中的图像 2,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Remove the Stops: 步骤 4 中的图像 3,3
    • The stoppers are snapped in place with plastic at the top left and right side of the glovebox. Use a flathead screw driver to unsnap these hinges from their place.
    • Using one hand, push the glovebox slightly closed to create space. Using the other hand, rotate the piece and pull outward (perpendicular from the wall of the glovebox) until the hinge comes free.
    • Repeat for both stoppers on each side.
  5. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: 步骤 5 中的图像 1,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: 步骤 5 中的图像 2,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Locate and Remove the Air Filter Holder: 步骤 5 中的图像 3,3
    • Press inward on the two plastic pieces on each side of the air filter and pull towards yourself for removal.
  6. 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: 步骤 6 中的图像 1,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: 步骤 6 中的图像 2,3 2005-2010 Honda Odyssey Cabin Air Filter Replacement, Take Out the Old Air Filter and Replace: 步骤 6 中的图像 3,3
    • The air filter will be in the removed holder.
    • Remove the old air filter and replace it with the new air filter. There will be an arrow to point in the direction of "air flow". Make sure these arrows match on both the container and the filter.
    • Place the container holding the new air filter back and push until it snaps into place.
    • Use these directions in reverse to rebuild your glovebox.
结论
另外一个人完成了本指南。
团队
UM-KIM-S21S52G20 UM-KIM-S21S52G20 的会员
Community
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 130
总计 3,189
