跳转到主内容
2005-2012 Toyota Yaris Spark Plug Replacement
你所需要的
  1. 2005-2012 Toyota Yaris Spark Plug Replacement, Spark Plug: 步骤 1 中的图像 1,2 2005-2012 Toyota Yaris Spark Plug Replacement, Spark Plug: 步骤 1 中的图像 2,2
    • Remove the four bolts from the engine cover using a 10 mm socket wrench.
    • Additionally, you can use the wrench to loosen the bolts and then swap for your hands or a spinner handle to completely unscrew them.
  2. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 2 中的图像 1,2 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 2 中的图像 2,2
    • Lift the cap off and set it to the side.
    • You will see four ignition coils. For this tutorial, we will only replace one of the sockets.
  3. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 3 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 3 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 3 中的图像 3,3
    • Remove the ignition coil connector by pushing down on the end of the clip and unplugging it.
    • Unscrew the bolt on the other end of the socket plug using the 10 mm socket wrench.
  4. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 4 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 4 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 4 中的图像 3,3
    • Remove the ignition coil to reveal the spark plug cavity.
  5. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 5 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 5 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 5 中的图像 3,3
    • Remove the adapter and 10mm socket from the socket wrench and replace it with the 6" extension adapter and spark plug socket
  6. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 6 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 6 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 6 中的图像 3,3
    • Too much force can cause your spark plug to crack. Unscrew it carefully to ensure no debris falls into the hole.
    • Insert a 6" extension adapter and spark plug socket wrench into the cavity where your spark plug is located. Make sure it reaches and securely grabs onto the spark plug.
    • Remove the spark plug by pulling the socket wrench towards you, and loosen it until it unscrews completely.
    • To be safer, start by using the wrench to loosen it, then remove the wrench handle and unscrew it the rest of the way with your hands.
    • Lift the wrench and the spark plug out of the cavity.
  7. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 7 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 7 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 7 中的图像 3,3
    • After you remove the old spark plug, take out your new spark plug and remove its plastic protector.
  8. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 8 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 8 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 8 中的图像 3,3
    • Once you remove the white protector, take out the spark plug boot protector and open it to spread its lubricant across the screw area of the new spark plug.
    • Anti-Seize Lubricant is used to allow for easy spark plug removal in the future.
  9. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 9 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 9 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 9 中的图像 3,3
    • Make sure you tighten enough to minimize the risk of the spark plug being removed from the engine.
    • Fit your new spark plug into the socket, and insert it into the cavity.
    • Tighten the spark plug by pushing the wrench away from you, doing so until it's completely screwed in.
    • To avoid damaging the spark plug while tightening it, start by screwing in the plug with your hands, then add the wrench handle and tighten until it's secure.
  10. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 10 中的图像 1,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 10 中的图像 2,3 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 10 中的图像 3,3
    • Insert the ignition coil back into the cavity, plug in the connector, and screw in the bolt to secure it.
    • If your ignition coil connector's tab broke like this one did, you can use zip-ties to secure it or replace it. (Part #: 90980-11885)
  11. 2005-2012 Toyota Yaris Spark Plug Replacement: 步骤 11 中的图像 1,1
    • If more than one spark plug is damaged, repeat steps 5-11 for the rest of them.
终点
2等其他人完成本指南。
团队
CSU Los Angeles, Team 13-5, Ribeiro Fall 2023 CSU Los Angeles, Team 13-5, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S13G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 145
过去 30 天: 371
总计 1,326
