跳转到主内容
2005-2012 Toyota RAV4 Headlight Replacement
  1. 2005-2012 Toyota RAV4 Headlight Replacement, Headlight: 步骤 1 中的图像 1,1
    • Turn off your car, use your emergency break to secure the car and pop open the hood.
    • Make sure the engine is not hot before working under the hood of the car.
  2. 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 2 中的图像 1,2 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 2 中的图像 2,2
    • Under the hood of the car, locate a black cable towards the grille on the drivers side that leads to the back of the headlight. The bulb is located here.
  3. 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 3 中的图像 1,3 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 3 中的图像 2,3 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 3 中的图像 3,3
    • Turn the bulb counter-clockwise using your hand and gently pull the headlight out.
  4. 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 4 中的图像 1,2 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 4 中的图像 2,2
    • The headlight is attached to a plug that has a clip. Push down on the clip and pull the bulb out at the same time with the opposite hand.
  5. 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 5 中的图像 1,3 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 5 中的图像 2,3 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 5 中的图像 3,3
    • Slide the new bulb into that same plug until you hear a click.
  6. 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 6 中的图像 1,2 2005-2012 Toyota RAV4 Headlight Replacement: 步骤 6 中的图像 2,2
    • Put the bulb into the same hole that it was removed from and turn clockwise until you hear another click. You are done!
结论
3等其他人完成本指南。
一条评论
This is a headlight BULB replacement, not a headlight replacement. Please consider changing the title, which is misleading. Thank you.
Barb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 31
过去 30 天: 200
总计 9,918
