跳转到主内容
2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly
你所需要的
  1. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, Stereo Unit: 步骤 1 中的图像 1,1
    • This is the front panel of the 2004 Mazda 3 Stereo-CD Player. It's listed under the model number: BN85-66-9RXA.
  2. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 2 中的图像 1,1
    • On the right side of the unit, designated by the letter R, remove 6 screws using a Phillips #2 screwdriver.
  3. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 3 中的图像 1,1
    • On the left side of unit, designated by the letter L, remove 6 screws using a Phillips #2 screwdriver.
    • Gently pull on the cable to disconnect it from the front panel.
    • Now you can fully detach the front panel as well as the LCD display from the unit.
  4. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 4 中的图像 1,1
    • On the top of the unit, remove 2 screws with a Phillips #2 screwdriver.
    • Lift and remove the top case from the unit.
  5. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 5 中的图像 1,1
    • On the bottom of the unit, remove 2 screws with the Phillips #2 screwdriver.
  6. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 6 中的图像 1,1
    • On the back of the unit, remove 8 screws with a Phillips #2 screwdriver.
    • Remove 1 screw with a Phillips #1 screwdriver.
    • Pull off both the bottom and top metal plates.
  7. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 7 中的图像 1,1
    • On the front of the unit, remove 4 screws with a Phillips #2 screwdriver.
  8. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 8 中的图像 1,1
    • On the left side of the unit, designated by the letter L, remove 2 screws with a Phillips #2 screwdriver.
  9. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 9 中的图像 1,1
    • On the right side of the unit, designated by the letter R, remove 2 screws with a Phillips #2 screwdriver.
    • Pull the front metal plate off the unit. Then lift the CD drive from the lower metal case.
  10. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly, CD Drive: 步骤 10 中的图像 1,1
    • Remove 2 screws with a Phillips #1 screwdriver from the front of the CD drive.
    • Very gently pull apart the top metal case from the CD drive without damaging the ribbon cable.
  11. 2004 Mazda 3 Stereo-CD Player (BN85-66-9RXA) Disassembly: 步骤 11 中的图像 1,1
    • Gently pull the ribbon cable from the connector on the CD drive logic board.
结论
2等其他人完成本指南。
Robin Nystrom
于06/13/16注册
182 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 37
总计 4,985
