跳转到主内容
加入维修社区 - 创建账户
2004-2008 Mazda RX-8 Tire Rotation
你所需要的
    1. 2004-2008 Mazda RX-8 Tire Rotation, 2004-2008 Mazda RX-8 Tire Rotation: 步骤 1 中的图像 1,1
      • Loosen lug nuts with the socket/wrench just until they begin to turn.
      • Removing lug nuts requires a 21mm socket.
      询问修复机器人
      添加评论
    2. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 2 中的图像 1,3 2004-2008 Mazda RX-8 Tire Rotation: 步骤 2 中的图像 2,3 2004-2008 Mazda RX-8 Tire Rotation: 步骤 2 中的图像 3,3
      • Place Jack under the car (as shown).
      • It's best to avoid using the jack included with the car. If at all possible, use at least a 2 ton floor jack.
      • Use the Jack Handle to crank up just enough so that the tire noticeably lifts off the ground.
      询问修复机器人
      添加评论
    3. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 3 中的图像 1,1
      • Put the jack stand under the car to ensure the car will not fall back down while you are working on it.
      询问修复机器人
      添加评论
    4. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 4 中的图像 1,1
      • Remove all lug nuts holding the wheel on the car.
      询问修复机器人
      添加评论
    5. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 5 中的图像 1,1
      • Remove the front wheel from the vehicle.
      询问修复机器人
      添加评论
    6. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 6 中的图像 1,1
      • With the front wheel off repeat step 4 and step 5 to remove the rear wheel as well.
      询问修复机器人
      添加评论
    7. 2004-2008 Mazda RX-8 Tire Rotation: 步骤 7 中的图像 1,1
      • Place the rear wheel on the front of the car and place the front wheel in the rear. Tighten up the lug nuts and your tire rotation is complete.
      • Begin to tighten the lug nuts as much as you can with the wheel in the air, and then lower the car to the ground to finish tightening.
      • Tighten the nuts in a star pattern to avoid over tightening one side leaving the wheel installed crooked
      • Mazda recommends that the lug nuts be torqued to 108 ft*lbs to ensure that the wheel is secure
      询问修复机器人
      添加评论
结论
Verify a second time that every piece nut is secure and tight. You may have to do this again in the future.
取消:我没有完成这个指南。
Gerrit Mouw
于05/01/15注册
253 声望
创作了2篇指南
团队
Cal Poly, Team 8-4, Regan Spring 2015 Cal Poly, Team 8-4, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G4
5 名成员
创作了31篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 3,127
