Locate the fuse box holder near the driver's side headlight.
Remove the cover by lifting the black tabs on the sides.
Remove the cover.
There will be a fuse map on the underside of the cover.
Use the tool that is inside the fuse box to remove the necessary fuse.
Use the fuse guide on the inside of the fuse cover, along with the nature of the electrical problem to help quickly find the faulty fuse
Replace the bad fuse with a new one.
Put the fuse box cover back on and secure the tabs on the side.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于05/08/15注册
118 声望
撰写一个指南
徽章: 9
+ 6更多徽章
CPSU-REGAN-S15S8G4
5 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 40
总计 7,995
