跳转到主内容
加入维修社区 - 创建账户
2004-2008 Mazda RX-8 Air Filter Replacement
    1. 2004-2008 Mazda RX-8 Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,1
      • Begin by opening the hood of the vehicle and locating the air filter cover.
      • The air filter is located in the middle of the front of the vehicle covered by a large black rectangular cover.
      询问修复机器人
      添加评论
    2. 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 2 中的图像 1,3 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 2 中的图像 2,3 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 2 中的图像 3,3
      • Locate the two tabs on either side of the front of the air filter cover. Grab and pop open these two tabs.
      • Push the air filter cover open with your fingers. The air filter will now be visible and begin to pop up.
      • Once the air filter pops up, you can grab it with your hands and begin to remove it from the cover that is still being held open.
      询问修复机器人
      添加评论
    3. 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 3 中的图像 1,2 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 3 中的图像 2,2
      • Gently pull the entire air filter out of the opened cover. This might take more than one set of hands in order to keep the cover open during removal.
      • The air filter is now fully removed and outside of the air filter cover. Obtain a new air filter to replace the old one.
      询问修复机器人
      添加评论
    4. 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 4 中的图像 1,3 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 4 中的图像 2,3 2004-2008 Mazda RX-8 Air Filter Replacement: 步骤 4 中的图像 3,3
      • Pry apart the cover of the air filter again to begin inserting your new air filter.
      • Gently push the new air filter back into the opened air filter cover the same way you removed it. The air filter will fall back into its resting position.
      • Once the new air filter has been fully inserted into the cover, close the cover and push the two tabs on the outside of the cover closed.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 8-4, Regan Spring 2015 Cal Poly, Team 8-4, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G4
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 4,827
