简介
Step by step, how to replace spark plugs on a 2004 Acura TSX.
It's recommended that you change your plugs every 30,000 miles
你所需要的
Locate the hood latch beside the driver's side door, right next to the left foot rest.
Pull the latch, should here a pop noise to know the hood has unlatched.
Walk in front of the car, reach your hand under the front of the hood to locate the latch.
Prop the latch and locate the spark plug cover.
Remove the cover where the Spark Plugs are located
Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place
Follow the Green circles
Use a 10 mm hex driver or socket to remove the four screws that are holding the Spark Plug wires in place.
Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
Once clips are removed,
Pull the remove the Ignition Coil out and place them in order the way you have pulled them out.
You should see 4 holes where the spark plugs are located.
Locate the spark plug at the bottom of the bore.
Use a ratchet, extension, and 5/8 socket to remove the plug by turning counterclockwise until it's free.
You can use a spark plug socket for an easier removal.
Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
The gap is bridged by corrosion.
The gap is too large.
The area around the gap is black and dark.
If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
Use a ratchet, extension, and 5/8 socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
After reinstalling all 4 spark plugs, follow steps 1-4 in reverse order and reattach the spark plug cover and close the hood.
5等其他人完成本指南。
