跳转到主内容
2003 Nissan 350z Spark Plug and Coil Pack Replacement
你所需要的
  1. 2003 Nissan 350z Spark Plug and Coil Pack Replacement, Cylinder 2 Spark Plug and Ignition Coil: 步骤 1 中的图像 1,2 2003 Nissan 350z Spark Plug and Coil Pack Replacement, Cylinder 2 Spark Plug and Ignition Coil: 步骤 1 中的图像 2,2
    • Pull the hood latch located in the drivers side footwell, to release the lock.
    • Open the hood and use the hood prop to secure.
  2. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 2 中的图像 1,2 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 2 中的图像 2,2
    • Use the push tab to release the battery cover and remove it from the engine bay.
  3. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 3 中的图像 1,2 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 3 中的图像 2,2
    • Loosen the ground terminal connected to the battery using a 10 mm socket and ratcheting wrench.
    • Place the ground terminal outside the battery cover and replace the cover.
    • The car battery circuit should be incomplete throughout the repair.
  4. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 4 中的图像 1,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 4 中的图像 2,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 4 中的图像 3,3
    • Use a ratcheting wrench and a 15 mm socket to remove the six 44.5 mm long bolts and two nuts on the strut tower brace.
  5. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 5 中的图像 1,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 5 中的图像 2,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 5 中的图像 3,3
    • Use a ratcheting wrench and a 10 mm socket to loosen and remove the three 12.7 mm bolts holding the wiring bracket in place.
  6. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 6 中的图像 1,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 6 中的图像 2,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 6 中的图像 3,3
    • Use the 10 mm socket wrench to remove the two 12.7 mm bolts that connect to the wiring harness brackets on each side of the ignition coil.
  7. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 7 中的图像 1,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 7 中的图像 2,3 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 7 中的图像 3,3
    • Usa a 10 mm socket wrench to remove the bolt holding the ignition coil.
    • Use a 16 mm deep socket to loosen the spark plug inside the valve cover.
    • Extend your magnet to retrieve the spark plug.
    • The 10 mm bolt holding the ignition coil is longer than the other 10 mm bolts. This bolt can only fit the ignition coil.
  8. 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 8 中的图像 1,2 2003 Nissan 350z Spark Plug and Coil Pack Replacement: 步骤 8 中的图像 2,2
    • Replace the faulty spark plugs and ignition coils with new ones.
结论
Carlos Ibanez
于03/03/24注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 54
总计 88
