当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Pinch the blue clips and remove them from the back of the wiring harness.
After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
即将完成!
终点
5等其他人完成本指南。
一条评论
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
