简介
It's recommended that you change your spark plugs every 30,000 miles.
你所需要的
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place.
Lift the plastic cover and set it aside.
You may need to use a wrench if your screws get separated from the bottom part under the spark plug cover.
Locate the spark plug at the bottom of the bore.
Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
Place duct tape on the inside of socket if the spark plug isn’t held when trying to pull it up. Also, tape the socket to the socket extension to ensure that it doesn’t fall into the bore.
Pull the plug out of the bore.
Référence de la bougie svp
Do you need to check ignition coils for each cylinders for tune up
If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
Use a ratchet, extension, and 5/8 inch socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
Repeat Steps 10-13 for the three remaining spark plugs.
You can get a torque wrench at Harbor freight for less than $20 and if you are a do-it-yourself person you will need this for every mechanical job you do. Lawn equipment,automobiles , or anything that uses machined parts you will always need a torque wrench. They will last a lifetime if you clean it and zero it after every job.
Denso specifically states in their spark plug manual that thread lubricant should not be used due to potential overtightening resulting to seal leakage.
After reinstalling all four spark plugs, follow Steps 3-9 in reverse order to reattach the spark plug cover and close the car's hood.
36等其他人完成本指南。
7条评论
Great instructions! I was able to change them pretty quickly.
First rule of thumb when changing spark plugs is to do it when the engine is cold. If you don't have a torque wrench it's ok, you can still tighten them properly. Easiest thing to do is put the new plug in the spark plug socket, attach the extension (8 or 10 in. is perfect) but not the ratchet. Thread the plug in until it is snug, then attach the ratchet to tighten. Most spark plug manufacturers put on the box (especially NGK) how much to tighten. Usually if the plug has no gasket, tighten 1/16 to 1/8 of a turn. If it has a gasket, tighten 1/2 to 2/3 of a turn. For an '05 Accord 4 cyl. they have a gasket.
I appreciate the thorough and precise instructions. I would add using anti-seize on new plug threads.
ssnider727 - 回复
All Done With Absolutely No
Is there ignition coils in each cylinders on the 2005 Accord
I change my oil every 5.000 miles like clockwork I did a compression test a few weeks ago and it's only lost about 2% of it compression and done 160.000 miles so well worth it
Graham Wells - 回复
What if u can’t get inside to unlock the hood
Paula Charron - 回复
My fob is not working properly I guess I checked the battery and it’s good still won’t open car a Sonata hybrid 2021 what do I do?
Paula Charron - 回复
