跳转到主内容
2003-2007 Honda Accord Key Fob Battery Replacement
你所需要的
视频概述
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 2 中的图像 1,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 2 中的图像 2,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 2 中的图像 3,3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 3 中的图像 1,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 3 中的图像 2,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 4 中的图像 1,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 4 中的图像 2,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 4 中的图像 3,3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 5 中的图像 1,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 5 中的图像 2,3 2003-2007 Honda Accord Key Fob Battery Replacement: 步骤 5 中的图像 3,3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
结论
3等其他人完成本指南。
eCuration
于05/19/17注册
378,307 声望
创作了236篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,085篇指南
一条评论
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 268
过去 30 天: 1,272
总计 145,097
