跳转到主内容
2003-2007 Honda Accord Cabin Air Filter Replacement
你所需要的
  1. 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,2 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,2
    • Open the passenger side door and locate the glove box. Open and empty the glove box.
  2. 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 2 中的图像 1,1
    • Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
  3. 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 3 中的图像 1,1
    • The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
  4. 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 4 中的图像 1,3 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 4 中的图像 2,3 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 4 中的图像 3,3
    • Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
    • Push the tabs inward and gently shake the housing free while pulling straight out.
    • When reassembling, push the filter tray in gently until both locking tabs click into position. The filter must be inserted into the tray fully for the tray to fit back in.
  5. 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 5 中的图像 1,1
    • Push the air filter out of the plastic housing from the bottom and discard.
  6. 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 6 中的图像 1,2 2003-2007 Honda Accord Cabin Air Filter Replacement: 步骤 6 中的图像 2,2
    • Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
    • Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
    • Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray to prevent any particulates passing around the filter.
结论
21等其他人完成本指南。
Shaun MacDonald
于10/03/12注册
2,558 声望
创作了8篇指南
团队
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G27
4 名成员
创作了22篇指南
一条评论
Good easy to understand directions and removal of cabin air filter . Thank You
raysanchez120 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 38
过去 30 天: 153
总计 31,870
