跳转到主内容
2003-2007 Honda Accord Battery Replacement
你所需要的
  1. 2003-2007 Honda Accord Battery Replacement, Battery: 步骤 1 中的图像 1,2 2003-2007 Honda Accord Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the latch to open your hood, normally located by your left foot when sitting in the driver's seat.
    • After lifting the latch, open your hood and securely hold it up.
  2. 2003-2007 Honda Accord Battery Replacement: 步骤 2 中的图像 1,3 2003-2007 Honda Accord Battery Replacement: 步骤 2 中的图像 2,3 2003-2007 Honda Accord Battery Replacement: 步骤 2 中的图像 3,3
    • You will lose your radio station presets and clock time if you do not use a Memory Saver. One will NOT be used in this guide.
    • The battery is located on the front driver's side of the vehicle.
    • Begin using your ratchet to loosen and remove the negative (black) cable from the terminal.
    • You can use a rag or towel to cover the cable in order to prevent a short.
  3. 2003-2007 Honda Accord Battery Replacement: 步骤 3 中的图像 1,2 2003-2007 Honda Accord Battery Replacement: 步骤 3 中的图像 2,2
    • Loosen and remove the positive (Red) cable from the terminal.
  4. 2003-2007 Honda Accord Battery Replacement: 步骤 4 中的图像 1,3 2003-2007 Honda Accord Battery Replacement: 步骤 4 中的图像 2,3 2003-2007 Honda Accord Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the cross-bar that holds the battery in place by loosening both bolts.
    • Lift out the bracket.
  5. 2003-2007 Honda Accord Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery by lifting it straight up and out.
    • Avoid tilting the battery in order to prevent an acid spill.
  6. 2003-2007 Honda Accord Battery Replacement: 步骤 6 中的图像 1,1
    • Replace with a new battery.
    • Secure the battery cover back in place.
  7. 2003-2007 Honda Accord Battery Replacement: 步骤 7 中的图像 1,1
    • Place the cross-bar back in place.
    • When placing the cross-bar back in, make sure the bars are properly hooked into place.
  8. 2003-2007 Honda Accord Battery Replacement: 步骤 8 中的图像 1,3 2003-2007 Honda Accord Battery Replacement: 步骤 8 中的图像 2,3 2003-2007 Honda Accord Battery Replacement: 步骤 8 中的图像 3,3
    • Repeat the steps in reverse order to properly secure battery.
  9. 2003-2007 Honda Accord Battery Replacement: 步骤 9 中的图像 1,1
    • Start your car in order to make sure all of your electronic components are working properly.
结论
To reassemble the battery, follow these instructions in reverse order.
10等其他人完成本指南。
团队
Cal Poly, Team 15-4, Green Fall 2015 Cal Poly, Team 15-4, Green Fall 2015 的会员
CPSU-GREEN-F15S15G4
4 名成员
创作了4篇指南
3条评论
I believe you can remove the battery while the engine is running, one way to avoid radio reset. BUT the replacement procedure must be done FASTT! (I've done it twice without an issue, attempt at your own risk)
llcoolj0n - 回复
A 9 Volt battery plugged into the Cigarette Lighter Socket will save the SETTINGS; just keep it handy in the glove box because those batteries eventually fail.
jhgrossman - 回复
I changed my battery and the horn won’t shut off. What does that mean
Trenton Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 37
过去 30 天: 239
总计 61,920
