跳转到主内容
2003-2008 Toyota Corolla Headlight Bulb Replacement
你所需要的
  1. 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,2 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,2
    • Locate the handle to open the hood. It will be on the driver side of the car to the left.
    • Pull up on the handle and the hood should pop open a small amount.
  2. 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
    • Locate the prop and insert it into the hole in the hood.
  3. 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 3 中的图像 1,1
    • Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
  4. 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 4 中的图像 1,3 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 4 中的图像 2,3 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 4 中的图像 3,3
    • Twist assembly 45 degrees counter clockwise and pull straight out.
    • Be careful not to touch the glass on the new bulb. The oils from your hand could cause premature bulb failure.
  5. 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Lift up on the latch and pull. The bulb will come free from the wires.
  6. 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 6 中的图像 1,2 2003-2008 Toyota Corolla Headlight Bulb Replacement: 步骤 6 中的图像 2,2
    • Locate the other bulb, and repeat steps 3-5 to remove it.
结论
10等其他人完成本指南。
团队
Cal Poly, Team 17-4, Green Fall 2015 Cal Poly, Team 17-4, Green Fall 2015 的会员
CPSU-GREEN-F15S17G4
3 名成员
创作了4篇指南
一条评论
https://youtu.be/GHezj9nmbxE
Change headlight on your corolla in under one minute. So easy.
baxta777 - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 91
过去 30 天: 543
总计 89,332
