跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
找到2003-2008丰田卡罗拉保险盒
你所需要的
  1. 找到2003-2008丰田卡罗拉保险盒, 找到2003-2008丰田卡罗拉保险盒: 步骤 1 中的图像 1,1
    • 你会在左侧的面板下找到保险丝盒(不适用于英国右舵驾驶型号)。 它是一个黑色的方盒,所以你需要采取一些适当的工具来将其打开。
  2. 找到2003-2008丰田卡罗拉保险盒: 步骤 2 中的图像 1,1
    • 在去掉保护后,您将可以更换保险丝。在我的案例中我的38号保险丝出了问题。 (不同的型号,年份的汽车位置可能会变化。)更多请参考汽车说明书上的保险丝图。
结论
要重新组装您的汽车,请按照本指南的相反顺序进行操作。
24等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
27条评论
Will this work for Toyota Rukus as we have on our website http://www.toyotarukusclub.com too?
James Wools - 回复
1. This doesn't actually show anything about where it is or how you got to it.
2. The only "black box" in any of your photos is the dead pedal, which is definitely not where the fuses are.
How is this page the top result for toyota corolla fuse box in Google?
Dinksmack - 回复
Guys, the 2004 Corolla Japan made, the internal fuse panel does not locate behind the coins tray.
you must lay down on the floor of the car on driver side (hard due to less room), look up under the dash board you will find very samll black plastic cover (1 inch wide and 4 inches long), you may need a flash light, open this cover by press the letch which is located only your left hand side by laying down on the ground.
This is a verse thing ever I saw in Toyota, this fuse pannel is very hard to work, even the fuse diagram/location mentioned behind the cover is wrong as well. I just need to replace the power window fuse which was mentioned on the cover location at a wrong place, I found the menual was help full to find the location for the correct fuse only.
Hope it will help full and sorry for the typo if any.
Shahbaz -
Dink. I’m so glad someone said it. I was just about to start yelling at my monitor.
gallain -
I finally found a forum that helped me fixed my ac not blowing hot air issue. I thought at first my compressor went out, the relay was burned from under the hood and I replaced that with no success, I even used the horn relay with no success. I tested the wiring and looked at every freakin thing. I too did not find the interior fuse box behind the coin box. It was there but way the f**k under the dashboard as the previous comment mentioned. I finally found the #24 fuse 10 Amp was burned up. I replaced it and that wonderful cold air came out once again. I almost took this car to a mechanic and I knew it would cost a pretty penny. Hope this helps the next fellow.
crgarcia68 - 回复
添加评论
浏览统计数据:
过去 24 小时: 86
过去 7 天: 537
过去 30 天: 2,384
总计 337,879
