跳转到主内容
2003-2008 Pontiac Vibe Air Fuel Sensor Replacement
你所需要的
  1. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement, Air Fuel Sensor: 步骤 1 中的图像 1,2 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement, Air Fuel Sensor: 步骤 1 中的图像 2,2
    • WARNING: Hazardous situation which, if not avoided, could result in death or serious injury. Make sure the engine is off!
    • Open the hood and locate the old air fuel sensor.
    • The air fuel sensor is located above the catalytic converter (upstream).
  2. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 2 中的图像 1,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 2 中的图像 2,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 2 中的图像 3,3
    • Disconnect one end of the old sensor by pressing the button. The circle in the first image shows the button.
    • The tab can be hard to remove! You may need to use a screwdriver to disconnect it.
    • Listen for an audible click.
  3. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 3 中的图像 1,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 3 中的图像 2,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 3 中的图像 3,3
    • Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor.
    • Turn the wrench counterclockwise until the old air fuel sensor detaches.
    • Pull out the old air fuel sensor.
  4. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 4 中的图像 1,2 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 4 中的图像 2,2
    • Locate the new air fuel sensor.
    • Locate the tube of anti-seize lubricant that came with the new sensor.
    • Apply the oil lightly to the threads.
    • The oil is named DENSO oil. It will lubricate and provide protection for the threads (circled in the first picture).
    • Use gloves to protect your hands!
  5. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 5 中的图像 1,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 5 中的图像 2,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 5 中的图像 3,3
    • Insert the newly oiled air fuel sensor.
    • Tighten the sensor with the O2 sensor wrench.
  6. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 6 中的图像 1,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 6 中的图像 2,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 6 中的图像 3,3
    • Connect the tab to the upstream.
    • You will hear a click once the tab is connected to the upstream.
  7. 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 7 中的图像 1,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 7 中的图像 2,3 2003-2008 Pontiac Vibe Air Fuel Sensor Replacement: 步骤 7 中的图像 3,3
    • Turn your ignition on.
    • Check your dashboard to see if the check engine light is still on.
    • If the light is still on, turn the car off and wait a few minutes. Then turn the car back on and check the light again.
    • If the check engine light is still on, then use a code reader to see what is wrong with the car.
结论
Erin Rodgers
于09/30/21注册
181 声望
撰写一个指南
一条评论
STEP 3 SAYS "Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor." DOWNSTREAM? I thought we were working on UPSTREAM. I'm goin fishing !!!
William Colwell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 36
总计 1,364
