跳转到主内容
简介
It is very easy to remove and replace your headlights in your 2002 Toyota Tacoma. You can save a lot of time by replacing the bulb yourself. The replacement is a H4 9003 bulb. The process is easy and requires no tools to get the job done.
工具
没有特定工具。
配件
  1. Pull the lever under the steering wheel.
    • Pull the lever under the steering wheel.
  2. Pull up on the lever under the hood. At the same time, lift the hood of the car.
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. Remove the metal rod. Insert the metal rod to hold the hood in place.
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. Pinch the rubber cover and disconnect the headlight bulb. Pinch the rubber cover and disconnect the headlight bulb.
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. Remove the headlight bulb cover when you are ready to install it.
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
结论
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
另外一个人完成了本指南。
Drake Fenwick
于2021年02月17日注册
133 信誉积分
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 21
总计 65
