跳转到主内容
2002 Toyota Tacoma Headlight Bulb Replacement
你所需要的
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 2 中的图像 1,2 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 2 中的图像 2,2
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 4 中的图像 1,2 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 4 中的图像 2,2
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 5 中的图像 1,1
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
结论
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
另外一个人完成了本指南。
Drake Fenwick
于02/17/21注册
133 声望
撰写一个指南
一条评论
thank you, saved me alot of time.
harley cortez - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 15
总计 1,384
