跳转到主内容
2002 Toyota Solara Headlight Bulb Replacement
  1. 2002 Toyota Solara Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • Open the hood of the car by pulling the tab near the driver side floor.
  2. 2002 Toyota Solara Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2002 Toyota Solara Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2002 Toyota Solara Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Locate where to access the bulb.
    • Remove the electrical connector by placing index finger underneath and thumb on top, pulling with steady force until it is disconnected.
  3. 2002 Toyota Solara Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2002 Toyota Solara Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • Remove rubber grommet surrounding the headlight bulb and set it aside.
  4. 2002 Toyota Solara Headlight Bulb Replacement: 步骤 4 中的图像 1,2 2002 Toyota Solara Headlight Bulb Replacement: 步骤 4 中的图像 2,2
    • Release the headlight bulb by turning the housing counterclockwise and pulling until the bulb is released. Once removed, replace the headlight bulb.
结论
Victoria Jones
于03/30/20注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 709
