跳转到主内容
2002-2006 Toyota Camry Key Fob Battery Replacement
你所需要的
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 2 中的图像 1,1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 3 中的图像 1,1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 4 中的图像 1,2 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 5 中的图像 1,1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: 步骤 6 中的图像 1,1
    • Reassemble the fob, using your hands to press the two parts together.
结论
Salman Abu Mazen
于09/27/21注册
140 声望
撰写一个指南
团队
UM-Willis-F21S51G7 UM-Willis-F21S51G7 的会员
Community
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 45
过去 30 天: 220
总计 5,096
