跳转到主内容
2002-2008 Dodge Ram 1500 Headlight Assembly Replacement
你所需要的
  1. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: 步骤 1 中的图像 1,3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: 步骤 1 中的图像 2,3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement, Headlight Assembly: 步骤 1 中的图像 3,3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 2 中的图像 1,1
    • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
  3. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 3 中的图像 1,3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 3 中的图像 2,3 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 3 中的图像 3,3
    • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
    • Unscrew the second screw located approximately 6 inches below the first.
    • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
    • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
  4. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 4 中的图像 1,2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 4 中的图像 2,2
    • Approach this step with the process of unbuttoning a shirt in mind.
    • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
    • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
  5. 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 5 中的图像 1,2 2002-2008 Dodge Ram 1500 Headlight Assembly Replacement: 步骤 5 中的图像 2,2
    • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
    • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
    • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
结论
4等其他人完成本指南。
Michael Saggese
于10/05/12注册
1,048 声望
创作了6篇指南
团队
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G24
4 名成员
创作了11篇指南
9条评论
Don't forget to explain that there is a third bolt hidden behind the wheel frame under a rubber grommet Other than that hidden bolt. I had both headlights out and replaced in 30 mins.
sreilly623 - 回复
yep. found it. with all humbleness i ask, how do i get it? i am not a car guy. sorry. dont revoke man card.
theycallmemrc -
What wrench size for the bolt in the fender?
Kurt Smith - 回复
10mm for all three of them
Thomas Murray - 回复
I have a question are all 3 bolts the same I lost the one that goes underneath the headlight between the bumper will the other two one or the other still work until I can get replacement
lgweaver80 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 119
总计 53,124
