跳转到主内容
2002-2008 Dodge Ram 1500 Coolant replacement
你所需要的
  1. 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 步骤 1 中的图像 1,3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 步骤 1 中的图像 2,3 2002-2008 Dodge Ram 1500 Coolant replacement, Engine Coolant: 步骤 1 中的图像 3,3
    • Locate the coolant reservoir, near the front of the engine bay.
    • Do not remove the reservoir cap if the engine has overheated. Doing so may result in a steam explosion as pressure is released.
    • Locate the coolant reservoir cap and remove it by pressing down and turning it counterclockwise.
    • Never fill up the coolant while the engine is hot. This may cause the engine block to crack.
    • If the coolant level is low, fill up the reservoir using a 50/50 mixture of antifreeze and distilled water.
    • Many types of antifreeze coolant are pre-mixed, so read the instructions on the bottle before diluting with water.
  2. 2002-2008 Dodge Ram 1500 Coolant replacement: 步骤 2 中的图像 1,3 2002-2008 Dodge Ram 1500 Coolant replacement: 步骤 2 中的图像 2,3 2002-2008 Dodge Ram 1500 Coolant replacement: 步骤 2 中的图像 3,3
    • If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
    • Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
    • Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
    • Dispose of your used coolant at an auto parts shop or a landfill that accepts hazardous materials. Do not pour it down a storm drain or sink.
    • Remember to refill the reservoir tank with coolant before driving your Dodge truck. Driving without coolant will cause overheating and engine damage.
    • Due to limited resources the coolant was not actually drained in this guide.
结论
To dispose of your used coolant, take it to an automotive parts store or to any landfill that accepts hazardous materials. Do not pour coolant down any drains or sinks. Serious ecological damage could occur.
5等其他人完成本指南。
Michael Saggese
于10/05/12注册
1,096 声望
创作了6篇指南
团队
Cal Poly, Team 3-24, Amido Fall 2012 Cal Poly, Team 3-24, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G24
4 名成员
创作了11篇指南
一条评论
Thanks a million very helpful advice !
kenneth.williamsbam - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 48
过去 30 天: 189
总计 55,726
