跳转到主内容
加入维修社区 - 创建账户
2002-2009 Trailblazer Tail Light Bulb Replacement
你所需要的
    1. 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 3,3
      • Open up the trunk.
      • Remove the two screws next to the tail light using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    2. 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 2 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 2 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 2 中的图像 3,3
      • Position yourself with the tail light in front of you. Pull the tail light towards you.
      • Be careful because the headlight is connected to the car.
      • Apply pressure on the clip and pull it out to disconnect the tail light from the car.
      询问修复机器人
      添加评论
    3. 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 3 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 3 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 3 中的图像 3,3
      • Remove three screws that hold the lights in place, one on the top and two at the bottom using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    4. 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 4 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 4 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 4 中的图像 3,3
      • Pull up to expose the three lightbulbs.
      • From here, choose the bulb that needs to be replaced. In this guide, I will be replacing the stoplight.
      • Use your fingers to pinch the sides of the lightbulb.
      • Pull up to remove the bulb.
      添加评论
    5. 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 5 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 5 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 5 中的图像 3,3
      • Open the package of lightbulbs and take one out to use.
      • Apply a bit of pressure on the sides of the light bulb, and push it down into the socket.
      询问修复机器人
      添加评论
    6. 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 6 中的图像 1,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 6 中的图像 2,3 2002-2009 Trailblazer Tail Light Bulb Replacement: 步骤 6 中的图像 3,3
      • Reconnect the lights to the car.
      • Turn the car on to see if the lights are working correctly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Carlos Diaz
于03/19/22注册
160 声望
撰写一个指南
团队
CSU Los Angeles, Team G-33, Briggs Spring 2022 CSU Los Angeles, Team G-33, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22SGG33
1 名成员
创作了10篇指南
1指南评论
What if you do that and still does not work
Paul Polak - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 66
总计 6,400
