当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
MAKE SURE ENGINE IS COLD Locate the upper radiator hose and follow it to the location where the hose connects to the engine block. The hose clamps to a metal housing called the "water inlet." Loosen the band clamp that secures the hose to the water inlet with a screwdriver. Pull the hose off the inlet.
这个步骤还没有翻译 帮忙翻译一下
Place a bead of RTV gasket maker around the bottom edge of the water inlet. Place the water inlet over the thermostat and bolt it into place. Using RTV gasket maker instead of a gasket compensates for pitting that occurs in cast iron. It helps to promote a better seal between the engine and the inlet.
4等其他人完成本指南。
