跳转到主内容
2001-2005 Honda Civic Tail Light Replacement
你所需要的
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: 步骤 1 中的图像 1,1
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: 步骤 2 中的图像 1,1
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: 步骤 3 中的图像 1,1
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: 步骤 4 中的图像 1,1
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
结论
To re-install a tail light, follow these steps in reverse.
2等其他人完成本指南。
Tyler Smith
于10/23/13注册
828 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 的会员
UMASSD-VIJAYBHASKAR-F13S4G5
3 名成员
创作了5篇指南
一条评论
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 49
总计 8,337
