跳转到主内容
2001-2005 Honda Civic Headlight Bulb Replacement
你所需要的
  1. 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,3 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,3 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 3,3
    • Unlock your hood by pulling on the hood release located by the front of the driver side door.
    • Find the release near the center of the hood and push up on it to pull up the hood.
    • Prop the hood up in place. The end of the prop is found near the battery and it lays across the front of the hood.
  2. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • This step is only needed if you want to replace the headlight bulb on the driver's side
    • Pull up on the power steering fluid reservoir to take it out of the holder.
    • Set the reservoir to the side to make room near the headlight.
  3. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • This step is only needed if you want to replace the headlight bulb on the passenger's side.
    • Using the 10mm wrench undo the battery tie down by turning the bolt clockwise.
    • Move the battery out of the way of the headlight.
  4. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 4 中的图像 1,2 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 4 中的图像 2,2
    • Put on a pair of latex or nitrile gloves.
    • Take hold of the headlight plug located directly behind the headlight.
    • Turn the bulb a quarter turn counter-clockwise to unlock it.
    • Pull out the plug.
    • Be careful to not break the bulb when taking out the headlight.
  5. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 5 中的图像 1,3 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 5 中的图像 2,3 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 5 中的图像 3,3
    • Find the release on the lower part of the headlight plug.
    • Push down on the release while pulling on the base of the headlight to remove the headlight bulb.
  6. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Take the new headlight and plug it into the headlight plug
    • It is important that we wear the gloves and be careful with handling headlights as oils from human skin can easily damage them.
  7. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 7 中的图像 1,1
    • Reinsert the plug with the new headlight on it.
    • Turn the plug a quarter turn clockwise to lock it in.
    • Gently tug the plug to make sure it is locked in place. If it isn't, redo this step.
  8. 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 8 中的图像 1,2 2001-2005 Honda Civic Headlight Bulb Replacement: 步骤 8 中的图像 2,2
    • If you replaced the driver side headlight, plug the power steering fluid reservoir back in its place.
    • If you replaced the passenger side headlight, put the battery tie down back on by inserting the bolt and turning it counter-clockwise.
终点
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 186
总计 15,380
