跳转到主内容
2001-2006 Toyota Tundra Tailgate Replacement
你所需要的
  1. 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 步骤 1 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 步骤 1 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 步骤 1 中的图像 3,3
    • Use a Torx T30 screwdriver to remove the eight 27.0 mm screws on the inside of the tailgate securing the bed-liner panel to the tailgate.
  2. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 2 中的图像 1,2 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 2 中的图像 2,2
    • With the screws removed, lift and remove the bed-liner panel on the inside of the tailgate.
    • Do not touch the top of the tailgate. It's made from fiberglass that could cause splinters due to age or deterioration.
  3. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 3 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 3 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 3 中的图像 3,3
    • Remove the metal panel beneath the bed-liner panel.
    • The metal panel uses the same screws as the bed-liner panel and can be removed at the same time.
  4. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 4 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 4 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 4 中的图像 3,3
    • Grasp the cables and push inwards with both hands until the tailgate is released from the truck bed.
  5. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 5 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 5 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 5 中的图像 3,3
    • Open the tailgate until it is flat or parallel with the ground.
  6. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 6 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 6 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 6 中的图像 3,3
    • Remove the cables that connect the tailgate to the truck bed by prying the metal tab towards you using the flat head bit on the screwdriver.
    • Pry the tab up until the cable can be removed from the tailgate cable bolt.
    • The tailgate may need to be lifted up slightly to remove the cable from the tailgate cable bolt.
    • Repeat for both sides of the tailgate.
  7. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 7 中的图像 1,2 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 7 中的图像 2,2
    • Lift the tailgate until it forms a 45° angle with the horizontal.
  8. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 8 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 8 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 8 中的图像 3,3
    • Detach the right side of the tailgate by lifting it away from the truck at a 45° angle.
  9. 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 9 中的图像 1,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 9 中的图像 2,3 2001-2006 Toyota Tundra Tailgate Replacement: 步骤 9 中的图像 3,3
    • Pull the left side of the tailgate away from the left side of the truck to detach it.
结论
Matt Pires
于04/19/23注册
169 声望
撰写一个指南
团队
UC Davis, Team 2-7, Morris Spring 2023 UC Davis, Team 2-7, Morris Spring 2023 的会员
UCD-MORRIS-S23S2G7
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 120
总计 1,003
