跳转到主内容
2001-2006 Mini Cooper Radio Replacement
你所需要的
  1. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 步骤 1 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 步骤 1 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 步骤 1 中的图像 3,3
    • Grab the knee bolster panel under the steering column with both hands.
    • Pull it down and out.
    • Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
  2. 2001-2006 Mini Cooper Radio Replacement: 步骤 2 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement: 步骤 2 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement: 步骤 2 中的图像 3,3
    • Open the glovebox.
    • Using a Torx screwdriver with a T20 tip, remove the two M5 x 2.5 x 30 screws in the right hand side pillar.
    • Minis in America will usually have a cup holder attached with these 2 screws on the right. It will come off when the 2 screws are removed and can be set to the side.
  3. 2001-2006 Mini Cooper Radio Replacement: 步骤 3 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement: 步骤 3 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement: 步骤 3 中的图像 3,3
    • With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
    • Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
    • Pull each side of the middle dash panel until it pops out, like the previous ones.
  4. 2001-2006 Mini Cooper Radio Replacement: 步骤 4 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement: 步骤 4 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement: 步骤 4 中的图像 3,3
    • Grab the left hand side pillar, then pull it out and to the left.
    • Grab the right hand side pillar, then pull it out and to the right.
    • The four screws holding the radio in should now be exposed.
  5. 2001-2006 Mini Cooper Radio Replacement: 步骤 5 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement: 步骤 5 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement: 步骤 5 中的图像 3,3
    • Using a screwdriver with a T20 bit, take out the four M3 x 2 x 20 screws holding the radio in place.
  6. 2001-2006 Mini Cooper Radio Replacement: 步骤 6 中的图像 1,2 2001-2006 Mini Cooper Radio Replacement: 步骤 6 中的图像 2,2
    • Grab the radio and gently pull it out of the dash.
  7. 2001-2006 Mini Cooper Radio Replacement: 步骤 7 中的图像 1,3 2001-2006 Mini Cooper Radio Replacement: 步骤 7 中的图像 2,3 2001-2006 Mini Cooper Radio Replacement: 步骤 7 中的图像 3,3
    • Pinch the antenna connector and pull it straight out.
  8. 2001-2006 Mini Cooper Radio Replacement: 步骤 8 中的图像 1,2 2001-2006 Mini Cooper Radio Replacement: 步骤 8 中的图像 2,2
    • For the main connector, pinch the lever arm with the piece of plastic next to it.
    • Lift up on the arm and pull the connector out.
    • The radio can now be removed from the car.
结论
5等其他人完成本指南。
一条评论
I bought everything to install a aftermarket radio in my 2005. Mini s. Everything lights up. Stations tune in but no sound
Roy Ober - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 59
过去 30 天: 242
总计 11,439
