跳转到主内容
2001-2006 Mini Cooper Cabin Air Filter Replacement
  1. 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,3 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,3 2001-2006 Mini Cooper Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 3,3
    • Locate the air filter housing unit below the glove box.
    • Open housing unit to reach air filter by locating the three clips, one on the rear of the box and the two on the front.
    • Open the rear clip first by applying an outward and downward force. Repeat process for the front clips.
  2. 2001-2006 Mini Cooper Cabin Air Filter Replacement: 步骤 2 中的图像 1,2 2001-2006 Mini Cooper Cabin Air Filter Replacement: 步骤 2 中的图像 2,2
    • Filter lays in a pair of guide rails for easy removal and replacement.
    • Pinch base of filter with thumb.
    • Once the filter is pinched it can easily be pulled out by the guide rails with moderate force.
  3. 2001-2006 Mini Cooper Cabin Air Filter Replacement: 步骤 3 中的图像 1,1
    • Replace the old filter with the new filter.
    • Reassemble the air filter by following the guide in reverse. On the side of the filter, there should be writing telling which direction the air flow goes in for putting it back in right way up. The air should be flowing into the foot well so you want the arrows pointing down.
终点
5等其他人完成本指南。
Eli
于10/10/13注册
363 声望
撰写一个指南
团队
Cal Poly, Team 8-19, Regan Fall 2013 Cal Poly, Team 8-19, Regan Fall 2013 的会员
CPSU-REGAN-F13S8G19
3 名成员
创作了4篇指南
一条评论
thank you for your page…you made it easy to understand…and the pics were great also!
Debbie Ross - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 75
总计 7,746
