跳转到主内容
2001-2007 Ford Escape Headlight Replacement
你所需要的
  1. 2001-2007 Ford Escape Headlight Replacement, Headlight: 步骤 1 中的图像 1,1
    • Release the hood latch located under the dashboard on the driver side of the vehicle.
    • You will hear a pop sound once the hood is properly detached.
  2. 2001-2007 Ford Escape Headlight Replacement: 步骤 2 中的图像 1,1
    • Push in on the sides of the bulb plug and pull directly out. It may take a bit of wiggling and effort to remove the plug.
  3. 2001-2007 Ford Escape Headlight Replacement: 步骤 3 中的图像 1,2 2001-2007 Ford Escape Headlight Replacement: 步骤 3 中的图像 2,2
    • Remove the rubber boot surrounding the housing. It will peel off when pulling the tabs to the side.
    • You may need a pry tool to remove the rubber boot. Always use an appropriate pry tool for the job.
  4. 2001-2007 Ford Escape Headlight Replacement: 步骤 4 中的图像 1,2 2001-2007 Ford Escape Headlight Replacement: 步骤 4 中的图像 2,2
    • Unlatch the bulb retention clip by pushing in on the two circle pins and pushing them apart.
    • They're similar to springs and will push away from each other once released.
  5. 2001-2007 Ford Escape Headlight Replacement: 步骤 5 中的图像 1,1
    • Remove the bulb by pulling it directly out of the housing. Once the bar is out of the way, the bulb isn't held onto by any remaining parts.
    • Be careful when removing bulbs to not scratch or damage the glass portion. Shattered glass is potentially harmful.
  6. 2001-2007 Ford Escape Headlight Replacement: 步骤 6 中的图像 1,1
    • Line the new bulb along the housing and set it in place. Clip the bar back down into it's original position from step 4 to secure it in place.
    • Be careful when handling headlight bulbs. Do not get any fingerprints on the glass of the bulb. Fingerprints can heat up when the light is turned on and cause the bulb to fail. Always grab the bulb by the end.
  7. 2001-2007 Ford Escape Headlight Replacement: 步骤 7 中的图像 1,2 2001-2007 Ford Escape Headlight Replacement: 步骤 7 中的图像 2,2
    • Reverse steps 2 and 3 to finish installing the new bulb. These steps are mirrored on the driver side of the vehicle.
结论
To reassemble your device, follow these instructions in reverse order. Both the driver side and passenger side follow the same procedure.
另外一个人完成了本指南。
John Morrison
于03/23/21注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 88
总计 2,855
