简介
如果您的思域的机油已经黑到不能再黑了,本指南或许能为你提供帮助。
多年来,人们认为每3000英里(约4828km)是正确的换油里程,但事实并非如此。 今天的引擎是如此的优秀,使用传统的机油的发动机可以做到运行5000英里(约8046km)才需要更换机油。 合成机油甚至能够让引擎良好运行10000英里(16093km)。
你所需要的
提醒灯位于汽车仪表盘转速表和速度表之间。
当汽车熄火时,按住小计里程复位按钮。 转动启动开关到ON位但不要打到引擎启动START位,持续按着小计里程复位按钮约十秒,直到指示灯熄灭。
让旧油滤残留的油滴干,这通常会需要12-24小时。
带上你的旧机油和旧的油滤前往回收的地方吧。大多数的汽车零件商店和修理厂会无偿回收。 除此之外一些城市或者国家会提供上门回收旧机油和油滤。 详情参见美国石油协会的网站 http://www.recycleoil.org/
好了,听她发动起来吧。 grrrrrrrr
36等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
16条评论
You may need a breaker bar to remove the drain plug from the oil pan housing. Also, the manual recommends that the drain plug be replaced at each oil change. I have found this wildly unnecessary, but was able to buy a couple spares for less than $3.00 each through a dealership. The reason they recommend this is because the plug itself is made from a softer aluminum alloy. After 150K miles, they're nearly impossible to remove without a breaker bar. A new plug (which is slightly shorter in length) does help, and does not leak.
Good Question it is very use full guide. please A civic hybrid can be done using these instructions, but Honda recommends using a synthetic oil - 0W-20 I believe.
The washer is aluminum (crushed washer), not the drain plug (at least on my Civic 2001) and needs to be changed each time. My car is 180000 miles and the drain plug is as good as new.
This is a nice article. I have noticed that removing the filter can be really messy so I would suggest to put some rags underneath to catch all the oil from the filter. Also I use the jack to raise the car higher in order to speed up the draining process.
A quick tip when draining the oil is, once you have the drain plug removed, also remove the cap on top of the engine. This will help to drain more oil out and do it faster. Also check with your supplier to see if you can buy a magnetic drain plug. This pulls any metal shavings out of the circulating oil and is better for your engine and filter. Will be a few more dollars than a regular plug but worth the peace of mind in my opinion, particularly if your car is older. Happy driving!
