跳转到主内容
加入维修社区 - 创建账户
2000 GMC Sierra Lights Replacement
你所需要的
  1. 2000 GMC Sierra Lights Replacement, Headlights, Taillights, and an overhead light: 步骤 1 中的图像 1,1
    • Open your tailgate fully, exposing both sides where the tailgate sits.
  2. 2000 GMC Sierra Lights Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two phillips head screws located above and below the tailgate support.
  3. 2000 GMC Sierra Lights Replacement: 步骤 3 中的图像 1,1
    • Once the screws have been removed, simply pull off the taillight. The red plug is the taillight. Twist it a quarter turn counter clockwise, and pop it out.
  4. 2000 GMC Sierra Lights Replacement: 步骤 4 中的图像 1,1
    • Remove the old bulb and replace it with your new one.
    • Side note: Make sure replacement bulb is save voltage/amperage rating.
    • Open the hood and take a look above your headlights.
    • Two metal pins holding each of the headlights in place will need to be removed (no tool necessary).
    • Turn the plastic headlight mount counter clockwise by one quarter of a turn.
    • Then lift the pins up to fully remove them.
    • Once the pins have been removed, GENTLY pull your headlight upwards, towards you. The bulbs should now be exposed. The bulb on the top is your headlight.
    • As you did with the taillight bulb, turn the piece that is holding the bulb in place a quarter turn counter clockwise, and the bulb will pop out. Now your new bulb will take it's place.
结论
5等其他人完成本指南。
keith beaudoin
于10/11/13注册
275 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 的会员
UMASSD-VIJAYBHASKAR-F13S4G7
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 64
总计 970
