跳转到主内容
2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement
你所需要的
  1. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: 步骤 1 中的图像 1,3 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: 步骤 1 中的图像 2,3 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement, Suction Fuel System and Fuel Filter: 步骤 1 中的图像 3,3
    • Attach 10 mm socket to a 1/4" ratchet wrench and loosen the bolt on the left side and then the right.
  2. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: 步骤 2 中的图像 1,2 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: 步骤 2 中的图像 2,2
    • Apply the thread sealant to the four bolts that will be attached to the new top base of the new fuel filter.
  3. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: 步骤 3 中的图像 1,1
    • Screw the four bolts with the thread sealant to the new top base of the new fuel filter.
  4. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: 步骤 4 中的图像 1,1
    • Attach the two two-inch clamps to the two fuel lines.
    • Then attach the fuel lines with the two two-inch clamps to the new top base.
  5. 2000 Bayliner Trophy Suction Fuel System and Fuel Filter Replacement: 步骤 5 中的图像 1,1
    • Screw the two-inch clamps with the paddle screwdriver until is secure to the fuel line.
    • Repeat the previous process on the other fuel line.
    • Finally, screw the new Racor fuel filter to the top base.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 65
总计 1,122
