跳转到主内容
2000 Acura TL Battery Replacement
你所需要的
  1. 2000 Acura TL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before beginning this repair, make sure to turn off your vehicle and wait 10 minutes for it to cool down.
    • Use the socket wrench with a 10mm socket to loosen the bolts on the guard that sits on top of the battery.
  2. 2000 Acura TL Battery Replacement: 步骤 2 中的图像 1,1
    • Unhook the hooks that are on the side towards the bottom of the battery. Pull the guard off of the top of the battery.
  3. 2000 Acura TL Battery Replacement: 步骤 3 中的图像 1,2 2000 Acura TL Battery Replacement: 步骤 3 中的图像 2,2
    • Using the same socket, loosen the two bolts until you can pull the terminals off of the battery and out of the way.
  4. 2000 Acura TL Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery from the vehicle.
    • Grab the handle over the middle of the old battery and pull it out of the car and set it off to the side.
  5. 2000 Acura TL Battery Replacement: 步骤 5 中的图像 1,1
    • Place the new battery in the same spot as the old one. Make sure the connections for the terminals are in the correct spot to reconnect. the two connections should be towards the left if you are facing the car.
结论
After making sure all parts are secured on the battery. the car is ready to go! Dispose of the battery at your nearest auto parts store or at your city dump.
Joshua Lacerte
于03/24/21注册
121 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G8, Riel Spring 2021 UMass Dartmouth, Team S2-G8, Riel Spring 2021 的会员
UMASSD-RIEL-S21S2G8
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 14
总计 725
